It's on the driver's side, below the brake master cylinder. There is a large wiring harness that looks like it bolts to the sheet metal going into the van. It actually bolts to the PCM. Loosen the 10mm bolt and remove the wiring harness from the PCM. I think there is another bolt holding the PCM in place, it's been a while since I took mine out.
