Bronco II Ford Bronco II
TIming??
Old Mar 8, 2006 | 09:45 PM
Aggie05's Avatar
Aggie05
TIming??
On my 89 Bronco 2 i had the timing light on it, and im not sure where its suppose to be. there is a circle looking piece on the timing cover thing and also a pointer looking piece of metal. Which one should the white line be closer to?
Old Mar 9, 2006 | 07:14 PM
Ken00's Avatar
Ken00
If I recall correctly the pointer is what you use.
Old Mar 10, 2006 | 09:07 AM
Aggie05's Avatar
Aggie05
Ill give that a try, The truck is running okay but the gas mileage sucks. i replaced the intake gasket and forgot to mark the distributor when i pulled it out. So its been hit and miss with timing.
Old Mar 10, 2006 | 06:47 PM
Ken00's Avatar
Ken00
Can anyone confirm the proper timing pointer??
Old Mar 11, 2006 | 12:13 PM
Desert Dog's Avatar
Desert Dog
Pointer
The pointer is the correct one to use I also have an 89 make sure you pull the spout first.
Old Mar 12, 2006 | 06:33 PM
Aggie05's Avatar
Aggie05
pulled electrical plug set timing, with plus in she idles around 850 rpms thats good. Once the electrical plug is back in the timing mark isnt near the timing needle, thats normal right?
Old Mar 12, 2006 | 10:56 PM
Desert Dog's Avatar
Desert Dog
Timing
After you time it reinsert the spout conector,the computer will take over it will look different than the original setting that is ok .if you want to recheck pull the spout again and see if was where you had set it.Tourque your distributer and you are good to go.
