firing order
Old Mar 8, 2006 | 07:40 PM
55forder's Avatar
55forder
firing order
Well I am going to fire her up for the 1st time in years tonight. With the removal and rebuild of the engine, I lost my manual, and am installing new wires. I was looking for the firing order online, and found this:
Is this the right schematic for my 1978 Lincoln 302? (D8VE casting)
Thanks guys, and Im sure Ill be posting once I get home.
Rich
Old Mar 8, 2006 | 07:43 PM
kdmcinnes's Avatar
kdmcinnes
Fireing order should be stamped on your Intake.
Kyle
Old Mar 8, 2006 | 07:47 PM
55forder's Avatar
55forder
I have an aftermarket aluminum intake. Had I saved the old one instead of turning it into a boat anchor, Id have a look.
Rich
Old Mar 8, 2006 | 07:57 PM
mason55's Avatar
mason55
Rich, The correct firing order .... according to Chilton's book is: 1-5-4-2-6-3-7-8 for 302's after 1975 and up ..... distributor rotation is counterclockwise. Hope this helps.
Mason
Old Mar 8, 2006 | 07:59 PM
kdmcinnes's Avatar
kdmcinnes
I have a 351 W and the firing order is 1-3-7-2-6-5-4-8, so not sure on the 302 at this moment.
Kyle
Randy Jack's Avatar
Randy Jack
My Ford Performance Book says that the firing order shown in your picture is correct.
Old Mar 8, 2006 | 08:03 PM
55forder's Avatar
55forder
Thank you!
Rich
Old Mar 8, 2006 | 08:04 PM
jaye's Avatar
jaye
Rich,
My manual has the same as Mason 1-5-4-2-6-3-7-8.
Jaye
Old Mar 9, 2006 | 12:09 AM
55forder's Avatar
55forder
I wired ignition, filled her with oil, coolant, hooked up throttle cable, and when I went to install plug wires, I realized that the wires I got at.. (yep you guessed it,Kragen) -were the wrong ones. I got the wires for my year of engine, but forgot what I had dealt with before. I have an electronic ignition installed, and the wires were for the points system. (different dist. ends)
Therefore, no startup until day after tomorrow at the earliest.
Shucks!
Rich
Old Mar 9, 2006 | 05:59 AM
kdmcinnes's Avatar
kdmcinnes
That Sucks!, Keep us updated
Kyle
Old Mar 9, 2006 | 09:00 AM
Okiedokie's Avatar
Okiedokie
302 HO is same firing order as 351W. Sounds like yours is not HO. So your diagram is correct. Jow
