Please help, brake light prob
Old Mar 8, 2006 | 06:32 PM
600NITRO's Avatar
600NITRO
Haven't posted here in over 2 years, but I really could use someone's help. I have a 77 Ford F-150 4X4 w/ 351M. I picked my truck up today from the 3rd mechanic to try to fix the problem, he was unsuccessful, but at least gave me a diagnosis. The problem is that my driver's side brake light won't work. Also, whenever I go over a bump or shift from park to drive or reverse, the radio will cut off but come right back on. I've already had 2 mechanics check out all the bulbs and wiring in back of the truck and everything checks out. I told the mechanic that there may be a short or something in the steering column, so they took it apart, and now they are telling me that I need a directional switch. Is there any body out there that can tell me where would be a good place to start looking to find this part? I'm new to these classic trucks and am still learning, so any help would greatly be appreciated. Thanks.
Old Mar 8, 2006 | 06:52 PM
banjopicker66's Avatar
banjopicker66
Check the advertisers here. They carry that part for a variety of trucks, and probably yours.
Old Mar 8, 2006 | 11:39 PM
lscolonel's Avatar
lscolonel
I have a simalar problem in my 74 the tail lights always work but sometimes the driver side brake light stops working. I'm not having any luck with it any suggestions?
Old Mar 8, 2006 | 11:51 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check out the tech article: https://www.ford-trucks.com/article/...rd_Pickup.html
Usually problems like this can be traced to a bad ground.
Old Mar 9, 2006 | 07:01 PM
3ondatree's Avatar
3ondatree
I had the same problem. I ordered a turn signal switch from LMC truck for about $70 and installed it myself.
Old Mar 9, 2006 | 07:17 PM
Wheelin4fun's Avatar
Wheelin4fun
i also had the same problem in my 78 f150 the turn signal switch took care of the problem.
Old Mar 9, 2006 | 08:26 PM
greenhighboy's Avatar
greenhighboy
You can buy the turnsignal switch from your local part store.
Old Mar 9, 2006 | 09:42 PM
tcannon's Avatar
tcannon
brake light problem
you can get a new directional switch from auto zone for 67.99 or you can get a reair kit if you need the whole thing...
