hey just wundering someone posted a while back they found an international badge that fit with the f 350. couldn't remember if it was ebay or home made, any help greatly appreciated
Do the powerstroke badges on the doors have pins? My idea was to put one of the domed International badges with the T444E part next to it in place of the powerstroke badge.
No they do not. I bought a replacement set of the door emblems to add to my previous Early 99 (Early 99's have a Powerstroke sticker by the headlights and nothing on the door). They are only stuck on with super industrial tape (You know the kind)...no pins.
yes, and they are basically impossible to remove without damaging the paint on the door. i tried removing the badge to do the acetoning, but it wouldnt budge, so i did it with them on the truck and they turned out good. i want to get some international badges like Pop has, and put them on the tailgate like he has, plus on the space on the fender below the F-350 Lariat between the wheelwell and the badge, like where most guys with Banks' stuff have their stickers.
I will post some pics tomorrow night. As far as removing badges, I have always used dental floss/fishing line and a blowdryer.
Heat the badge for about 30-45 seconds and then "saw" the line between the badge and paint. There will be some adhesive to remove, but acetone would not be recomended. Just get some of the Goop bug and tar remover. It has a neglegable amount of solvent and a conditioner for finished surfaces.
Get some 15lb Fishin line,a hair dryer to heat up the emblem and then slide the line behind the emblem and it will cut thru the tape with ease,and you wont hurt the paint at all.
I have had the F350 Super Cruiser emblems on my mind for a long time. One of these days I will probably break down and drop the 100 bucks on a set.
thanks pop did you check out the psd badges and stoker stuff in his other auctions, it's impessive! to say the least i think i'm going to rebadge the whole truck!
Yes, I looked at his other stuff, but I'm not real enthused with the older "Powerstroke" logo, upon which a lot of his stuff seems to be loosely based.
