will not downshift
Old Mar 8, 2006 | 02:49 PM
willwo12's Avatar
willwo12
will not downshift
Hi, I am a first time poster here. Have a 96 f350 7.3.auto . Yesterday while driving the truck seemed to lock in third gear while coming to a stop, stalling the engine. I shifted to neutral cranked the engine, shifted to drive and the engine stalled again. Again cranked, then shifted to 1 and it did not stall. I friend told me disconnect the wiring harness on the shift linkage, which i did and it seemed to correct the problem. I tried it again today, same thing, locked up. Again disconnected and reconnected the wiring drove for several miles and seems okay. I know it is going to happen again. Any ideas?
Thank you
will
Old Mar 8, 2006 | 05:22 PM
444dieselrod's Avatar
444dieselrod
low trans fluid will make the converter stay locked, and do this, could be low, but I realy dont know.
Diesel Rod
Old Mar 8, 2006 | 06:08 PM
DaBigTow's Avatar
DaBigTow
Could also be the switch assembly on the tranny (where you're unplugging it), PCM might not realize it's in gear. Ford calls it a "Transmission Range Sensor"; a set of resistors in series to tell what position the shift lever is in.
Old Mar 8, 2006 | 08:53 PM
willwo12's Avatar
willwo12
Thanks for the help. I will check both.. I did drive it today about 30 miles without any problems. It seems like a hit or miss problem.
Thanks again. I will let you know how it goes.
will
