Help...NO POWER
Old Mar 8, 2006 | 01:28 PM
Black SuperCab FX4's Avatar
Black SuperCab FX4
Help...NO POWER
I just replaced the engine in my 1991 ( 5.0 ) with an engine out of an 89 ( also 5.0) the problem is no power, the engine in the 89 ran good and I drove it home and pulled the engine, everything seems to check out good, checked firing order, wires, everything seems right, the engine seems to run good at idle, just won't pull, The truck won't get fast enough to even shift out of low gear......
Any suggestions ???????????????????
Old Mar 8, 2006 | 04:04 PM
subford's Avatar
subford
Did you time it with the SPOUT in?
Old Mar 8, 2006 | 04:05 PM
subford's Avatar
subford
Check the exhaust system, may be clogged.
