HVAC control vacuum source?
Old Mar 8, 2006 | 11:33 AM
slickster's Avatar
slickster
4wd Low
89 f250....the ventilation controls do nothing....where is the vacuum source for the controls under the hood...where is the "coffee can" if there is one?...good place to start...thanks to all...Mick...oh yeah....460, auto...
Old Mar 8, 2006 | 03:48 PM
subford's Avatar
subford
The "coffee can" is not used for the ventilation controls, it is used for powertrain control.
The ventilation controls reservoir is a black ball about 3.5 inch across, not hard to spot.
Their should be a hose leaving the ball, going through a "T", a check valve and then push on to the intake manifold at a vacuum fitting.
From the "T" there should be a hose running to the vacuum control in the cab.
Old Mar 10, 2006 | 07:24 AM
slickster's Avatar
slickster
4wd Low
SUBFORD....thanks for the reply...I'll check it out...Mick
dogg4585
17
Dec 27, 2010 08:45 PM
DBLX
2004 - 2008 F150
May 24, 2009 01:32 PM
LARIAT 85
Sep 5, 2007 06:04 PM
grey77
29
Apr 7, 2006 02:15 PM
lbyblock
Jul 16, 2002 10:56 AM
