Ball Joints
Old Feb 4, 2001 | 11:46 PM
abeln's Avatar
abeln
Ball Joints
Old Feb 15, 2001 | 09:24 PM
bigf150's Avatar
bigf150
Ball Joints
Just wondering if i need a ball joint press to take out ball joints and if i gotta take the axle out and if so how does my axle on my 79 f150 come about coming out?
Anthony DiPietro
79 F150 Ranger
Old Feb 16, 2001 | 03:59 PM
greg ne's Avatar
greg ne
Ball Joints
I don't know for sure about the press ? but I have helped change them before and we got them out with a big hammer. Yes the axle has to come out, you have to take the front hub apart completely then pull the axle out through the hub opening. You will probably want to pull the diff cover off and drain the oil because when you push the axles back in you can't help but push some of the grime that has built up in the tubes from twenty years of driving into the center section, then you can clean what has been pushed in out so you don't ruin the bearings and gears. Good luck Greg NE
Old Feb 16, 2001 | 10:35 PM
bigf150's Avatar
bigf150
Ball Joints
What did you use to get the new ones in?
Anthony DiPietro
79 F150 Ranger
Old Feb 17, 2001 | 04:21 PM
jsorg76f250's Avatar
jsorg76f250
Ball Joints
I did mine last November, needed the press and special 4 wheel drive adapter. It's needed to take them out and put them in. I went to local parts store (Murray's), they have tool "rental" program where you buy them, then get refund when you are done with them. I never did it before, could not believe how snug they were. Even the castle nut...I used propane torch and 4' cheater bar.
Old Feb 17, 2001 | 08:24 PM
greg ne's Avatar
greg ne
Ball Joints
I beleive we used a board and hit on it to get them back in real careful, been several years can't remember for sure. Sorry Greg Ne
Old Feb 17, 2001 | 09:02 PM
bigf150's Avatar
bigf150
Ball Joints
Ok thanks for the input i'll update on what happened when i get to doing it.
Anthony DiPietro
79 F150 Ranger
