Timing marks
Old Feb 18, 2001 | 01:34 AM
73mke390's Avatar
73mke390
Timing marks
What degree or timing mark (I'm not sure how to phrase it) do I use for the ignition timing on a 1973 390. Chiltons and Hanyes both say to look in the engine compartment, but my cab is a 78 f-150 Ranger XLT and I'm not sure what the chassis is from. I just finished the valve job and it starts, but I'd like to do it right. If you need engine numbers I can get them in the morning.
thanks-MikeD
Old Feb 18, 2001 | 01:57 AM
Ratsmoker's Avatar
Ratsmoker
Timing marks
[font size="1" color="#FF0000"]LAST EDITED ON 18-Feb-01 AT 03:00 AM (EST)[/font][p]I'm not quite sure what you mean either but there should be a metal pointer right above the harmonic balancer. Put a chalk mark at about 6 degrees BTDC, disconnect your vaccum advance and put a timing light on it. This is the factory setting but on my 390 it will backfire through the carb at this setting so you may need to advance it a little more to like 12BTDC. Hope I answered your question somewhere in here. I think all you wanted was the correct degree but just in case I threw the rest in.
Old Feb 18, 2001 | 04:26 AM
BigBrownTruck's Avatar
BigBrownTruck
Timing marks
I would say, advance it till it starts to ping under a load, then back it off slightly... try 10degrees BTDC as a start. On my smallblock, I just had distributor rebuilt and recurved. Before the centrifical advance was coming on too quickly. Before the rebuild I couldn't have it advanced beyond about 5degrees w/o ping... now I have it set at 11degrees w/ no ping. My 390 w/ Crane electronic ignition is set at 10degrees currently. Rotating the distributor clockwise, advances the timing, counterclockwise retards it. Too much advance you get ping... to little you loose power. Make sure you pull the vaccume advance off the distributor, and then reconnect when you are done.
BBT
Old Feb 18, 2001 | 10:49 AM
wnelson's Avatar
wnelson
Timing marks
The Terrible Blob
13
Feb 1, 2014 08:00 PM
rdweathers
Mar 31, 2011 08:56 AM
Tyson82
Mar 20, 2008 04:14 PM
baitmaster
Sep 13, 2005 12:19 AM
Mark76f250
Oct 10, 2003 01:58 PM
