Sponsored by: Innova
PKF1 Wiring Question
Old Mar 7, 2006 | 11:48 AM
theafus's Avatar
theafus
Hey KC how do I wire in the PKF1 on a 2000 F 150. Thanks
Old Mar 7, 2006 | 11:36 PM
IPACA9's Avatar
IPACA9
Sorry... long day.
Connect Red wire on the harness to Ignition
Connect Black wire to Ground
Connect Brown wire to the Active Output wire on your starter system
Connect Green to the TX on the harness that comes from the transponder ring
Connect Blue to the RX wire on the harness that comes from the transponder ring
When I test these I use a test light and turn the ignition ON. Test the wires on the harness plug that goes into the transponder ring around the ignition. Starting with the edge you will find that one of the outer wires is a ground. Then from the opposite side you will find your TX and the one next to it towards the inside of the harness is the RX. Hope this makes sense.
Old Mar 8, 2006 | 07:31 AM
theafus's Avatar
theafus
Thank You it will be a great help as soon as my module gets here I can get it in Thanks again
