ABS light is on and I'm going to have to replace the left front speed sensor on a 2000 4WD as per ABS scan. Tried replacing rear VSS first with no luck.
Anybody have any tips? Should I go ahead and replace both front sensors and repack left and right wheel bearings or wait for the right sensor to go?
I also need the torque spec for the final wheel bearing adjustment if anybody knows off hand.
