95 4r55e problem
Old Mar 6, 2006 | 05:20 PM
linlsc95's Avatar
linlsc95
95 4r55e problem
I have a 95 with the dreaded 4r55e trans.Here's my problem when you are at between 40 to 50 mph the trans shift's from od to 3 .In od the tach is at 1600 then it will jump to 3000 then back to 2000.I do not get a od light or code just did a full flush other then that it up shift's fine and it only drop shift's sometimes any feed back will be helpful
Old Mar 6, 2006 | 06:11 PM
SUPER6's Avatar
SUPER6
Probably Looking At A Valve Body Problem.
Old Mar 6, 2006 | 08:20 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Do a Google search for "5R55E Valve Body Rebuild Dairy", and you'll find lots of info on this. (Sorry I can't post the link here, but a search will turn it up.)
Old Mar 7, 2006 | 05:24 AM
marragtop's Avatar
marragtop
Did the problem start before or after you did the flush?
Old Mar 7, 2006 | 03:41 PM
linlsc95's Avatar
linlsc95
before i did the flush at first i though the shifter needing new bushings was the reason but no deal.This thing will shift prefect most of the time
