engine test question
Old Mar 6, 2006 | 02:44 PM
mrwrench's Avatar
mrwrench
are there any way to start a powerstroke out of the vehicle?
Old Mar 6, 2006 | 09:39 PM
F350_Hauler's Avatar
F350_Hauler
You would definitely need a good strong stand. Then just hook up the different required components and ingredients. You can find out a lot though by doing a compression check on the engine and by pulling the pan and checking out the contents. If the compression checks out, pull the pan, put a new oil pump in and put it in a truck or on a nice big, fast go-kart.
Old Mar 7, 2006 | 08:04 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Without being on an engine test stand? Not very feasable without being able to plug in all the electronics.
Old Mar 7, 2006 | 09:15 PM
F350_Hauler
That was my point. Plugging in the electronics and all necessary components would require a ton of work to set up. So do a compression check, check the pan contents, new oil pump and stick it back in your truck. I was kidding about the go-kart.
