Cavitation?
Old Mar 10, 2006 | 06:47 AM
travertine's Avatar
travertine
I want to thank you all for a good education on my question.
Old Mar 10, 2006 | 06:18 PM
Dave Sponaugle's Avatar
Dave Sponaugle
You are welcome, that is what we love to do.
Come back and see us with the next question real soon.
Old Mar 10, 2006 | 07:30 PM
Todd Dietz's Avatar
Todd Dietz
Question
Originally Posted by Dave Sponaugle
I am using Fleetcharge from NAPA now.
Pre charged with DCA 4 and pre diluted to 50/50 mix.
What could be easier.
That way I also know I can get compatable test strips when I need them.
O.K. How much Fleetcharge will I need to buy? and do I really need test strips, and if I do, where do I get those??
Thanks in advance as always...
Old Mar 10, 2006 | 08:50 PM
Dave Sponaugle
My engine was completely dry when I installed the last one.
As I remember it took about 7 gallons to fill everything up including the over flow tank.
Napa has the test strips.
You should test the Ph and nitrate levels every three months.
Old Mar 12, 2006 | 03:38 AM
dslmn's Avatar
dslmn
I doubt that your problem is cavitation or a blown head gasket. If it were, you would have water in the oil or leaking from your exhaust. I had the same problem with my 87 on two separate occasions. The first time it was the radiator cap and a leaking hose that only leaked under pressure and when hot. The second time it was the block heater. The heater element had corroded and would leak when the engine warmed up. Figured it out the hard way when it dumped the coolant hauling a load of wood. There is a third cause as well. After a hundred thousand miles, many of these trucks will start leaking fluid from holes worn in the top radiator hose boss. There is spot there on the inside of the radiator that collects grit, corrosion particles and sand grains left from the engine casting. Under flow, the grit acts like grinding compund and eventually wears through the housing. The resultant leak drops the fluid level below the hole and the coolant continues to evaporate through the hole. Unless you notice the wet spot or actually see the coolant spraying from the hole under pressure it's difficult to find. When it leaks, the fluid dribbles down onto the core and evaporates rapidly. the fix is easy, a simple weld or braze that any radiator shop can handle.
Old Mar 12, 2006 | 05:38 AM
diesel-weasel's Avatar
diesel-weasel
another place to check is dampness around your oil cooler ,end daps or O rings
Old Mar 12, 2006 | 05:39 AM
diesel-weasel
oops that should be end caps
Rentaro
89
Jul 8, 2013 01:08 AM
tygerof2
Jun 24, 2013 03:23 PM
turbojunkie
6.7L Power Stroke Diesel
Aug 1, 2011 07:09 PM
cornking
Jan 6, 2008 07:58 AM
ATSDRIVER
26
Dec 12, 2005 05:06 PM
