Offroad & 4x4
Add a leaf question
Old Mar 6, 2006 | 09:53 AM
bchunter's Avatar
bchunter
Add a leaf question
I was thinking about replacing the stock block in my lift system with an add a leaf, as some of you suggested since I have the blocks stacked right now (stock and lift). I was looking at Suspension Connection and a pair of add a leafs is really cheap, only $55.
What I was wondering is how do these things work? Do they replace the stock block? I see that I can get them in 2" or 3" so I figured I would need to get the size closest to the size of the block. But I was also wondering about the bump stop on the stock block. I guess if I get rid on it I would need some limiting straps or something to limit the amout of travel, correct?
I also have the airbags in here. They came with the truck lucky for me.
Once again, thanks a ton for all the help. I really appreciate it.
Old Mar 6, 2006 | 09:59 AM
Flareside94's Avatar
Flareside94
Are the add-a-leafs you're looking at short or long leaves?
I'm guessing that 55 dollar set is short. if not, hook a brother up with the URL lol.
Old Mar 6, 2006 | 10:02 AM
bchunter's Avatar
bchunter
Good question I do not know.
Here is the website:
http://www.suspensionconnection.com/
What is the difference and would it make a difference?
Old Mar 6, 2006 | 12:26 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
short will stiffen teh ride alot more, but give you a bit more lift
long aal's will give a less harsh ride, but they wont give you as much lift
i would go with te long ones
Old Mar 6, 2006 | 12:29 PM
bchunter's Avatar
bchunter
Can you recommend a place where I can look for some?
Also, will I need a limiting strap of some sort?
Thanks.
