cross member bolt choice
Old Mar 5, 2006 | 09:17 PM
mdamico's Avatar
mdamico
When i go ahead and remount all of my spring hangars, and my main cross member with supports, what do you guys recommend for bolt choice, i was thinking grade 8 hardened with a lock washer on the inside. Would that be sufficient?Any comments appreciated thanks...mike
Old Mar 5, 2006 | 09:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
The lock washer always goes on the side with the nut. Use grade 8 lock washers and flat washers. Do not put a flat washer with a lock washer, defeats the purpose. Use Locktite for extra insurance. Drill out the holes one at a time for a tight fit with the new bolts. You can use a slightly smaller set of bolts for initial line up while drilling.
Old Mar 6, 2006 | 02:16 PM
1975Ford's Avatar
1975Ford
Grade 8 on washer, lock washer and bolt and nut. Fine or Coarse thread will also work on that application.
