Old Mar 5, 2006 | 08:09 PM
71mopar383's Avatar
71mopar383
I have a 65 f-100 with a 352 any ideas on the comp ratio is and the head cc?
If I want to make it a 390 dont I just need to punch it .050 over and add 390 crank, rods and pistons?
Old Mar 6, 2006 | 09:52 AM
fordeverpower's Avatar
fordeverpower
you are right on with the 390 conversion, the heads are most likely between 67-74cc.
Old Mar 6, 2006 | 10:54 AM
66beater's Avatar
66beater
or use 360 pistons and get the compression up to more reasonable levels. 390 truck pistons are low compression.
Old Mar 6, 2006 | 12:30 PM
rusty70f100's Avatar
rusty70f100
I'd use either the TRW L2291 forged piston, or the KB-150 piston, depending on your desired compression ratio.
