Rear Brakes
Old Feb 27, 2001 | 06:52 PM
disvnvet's Avatar
disvnvet
Rear Brakes
Can anyone in this board tell me if the 67-79's had self adjusting rear brakes and whether the backing plate, etc will mount on a 60 rear.
Old Feb 27, 2001 | 07:48 PM
BigBrownTruck's Avatar
BigBrownTruck
Rear Brakes
Yes my 76 and 79 both have self adjusting rear drum brakes.... they have 9 inch axle though so I can't say about the Dana.
BBT
Old Feb 27, 2001 | 08:20 PM
disvnvet's Avatar
disvnvet
Rear Brakes
My 60 has a Ford Rearend. I think the Dana is different. It is also a 9" stock rear. Maybe it will fit. Can you tell me if it has a 5 bolt pattern and flat on the bottom side.
Old Mar 1, 2001 | 03:26 AM
fe4ever's Avatar
fe4ever
Rear Brakes
The Dana's had self adjusters also. but like all self adjusters, they usualy dont! you can adjust them with a screwdriver through the back of the backing plate (near the bottom). There is a rubber plug. Pop it out, and turn the adjusters by pushing the screwdriver handle UP. Make sure you have the tire off the ground so that you can spin it to tell when the brakes are getting tighter. If it's been a long time since the drums have been off, you may need to turn the adjust quite a bit.
Old Mar 1, 2001 | 10:33 AM
deleontow's Avatar
deleontow
Rear Brakes
