Sponsored by: Kumho
Dually drum to disc
Old Mar 5, 2006 | 05:28 PM
Snatch Block's Avatar
Snatch Block
Question Dually drum to disc
Has anyone converted the rear drums to a disc setup? I have a 90 F350 dually and want to know if someone has done this.
Thanks.
Old Mar 5, 2006 | 08:13 PM
Kenworth's Avatar
Kenworth
Your out of luck doing it with a stock rear end you will have to find a Dana 80 out of E-450 Cuttaway van they have disk brakes and still use the old imperial bolt pattern.
The big drawback about the 10.25 Ford thats under you truck is its very poor rear brakes. Drum brakes in general are crappy its why I won't go back to a regular 1 ton again only F-450s for me I started 6 years ago with a 88 F-Superduty (F-450) then a 90 F-Superduty now I have a 95 F-Superduty.
There is a disk brake conversion kit for the 10.25 but its only for SRW trucks.
Old Mar 6, 2006 | 06:01 AM
Snatch Block
thanks for the info.
Cheers!!
