Sponsored by: Real Truck
can someone help with these eec codes
Old Mar 5, 2006 | 04:40 PM
vrobb3's Avatar
vrobb3
Question can someone help with these eec codes
did a self check today on my f-250 codes as follow:
koeo hard
327
654
koeo memory
327
542
koer
327
kmow what the codes mean except for 327, egr voltage low, but what needs to be changed, egr, sensor, valve, switch, thanx in advance
Old Mar 5, 2006 | 04:54 PM
kgk's Avatar
kgk
I am looking for the answer to the codes 327 and 328
I am looking for the answer to the codes 327 and 328. For 1992 4.9
However my cruse control also does not work, which is why I pulled the codes.
I will be monitoring the reply's.
Please let me know if you find out something with the search feature of this site.
Old Mar 5, 2006 | 05:09 PM
vrobb3's Avatar
vrobb3
327 PFE sensor circuit voltage below Self-Test minimum.
328 Exhaust gas recirculation valve position sensor closed voltage lower than expected.
doing a google search came up with these, so I guess 327is the pfe sensor, would like confirmation on this before i buy the switch
Old Mar 5, 2006 | 05:11 PM
vrobb3's Avatar
vrobb3
don't think either of those has to do with cruise control
