Question pertaining to scale use
Old Mar 5, 2006 | 01:23 PM
Mazatrol's Avatar
Mazatrol
Question Question pertaining to scale use
How do you go about weighing your travel trailer or 5th wheel at a truck stop? Are the scales free or do you go inside and pay to use the scale? Are you allowed to unhook the tow vehicle to get a true trailer weight? Any info would be helpful.Thank you
Old Mar 5, 2006 | 02:45 PM
scafes's Avatar
scafes
No they are not free, but it is relatively cheap to weigh. At the scale I use, you pay after. The display will give you a number after the light turns green, which indicates that it has your weight. Go inside and when you pay they give you the readout. Some scales have three individual scales for front axle, rear axle, and trailer. This gives you all three at once. Not sure how accurate it is though, compared to separate weights, but it is convienent. I am sure you can unhook, but try to do it when no one is waiting as the truckers will be pissed.
Matt
Old Mar 5, 2006 | 03:25 PM
tjc transport's Avatar
tjc transport
i ain't rite
do a combined weight. pull off the scale, and disconnect in an out of the way spot agreed upon with the scale master. then rescale with the tow vehicle. subtract tow vehicle weight from combined weight and you have trailer weight.
example: truck and trailer combined weight, 11,450 lbs. truck weight 6,450 lbs. trailer weight is 5,000lbs.
Old Mar 5, 2006 | 07:09 PM
Mazatrol's Avatar
Mazatrol
Thank you for the information. I'd assume weighing the combined weight then the tow vehicle weight is considered two seperate weigh sessions therefore i'll be charged for two?
Old Mar 6, 2006 | 04:46 AM
tjc transport
i ain't rite
it all depends on the scale, the scale master, and how busy they are. there are some small supply houses that have scales that will do it for a set price. there is a plumbing supply here that has the scale readout in the office and a speaker at the scale. the girl in the office only charges $10 for a split weight deal cause all she has to do is look at the readout. and if they know you, they don't charge at all
Old Mar 6, 2006 | 10:12 AM
Mazatrol's Avatar
Mazatrol
Thank you tjc, you've been of great help.
Old Mar 6, 2006 | 03:43 PM
mhoefer's Avatar
mhoefer
Sometimes when gov't transport scales are closed, the weight can be seen from the truck, or you need a buddy to read the scale.
Just drive each axle on, note the weight, then move to the next axle. Dont jam the brakes, it ruins the scales. Note your two weights, front axle plus rear for truck = truck weight, note axle weight for trailer = trailer weight (not including tongue). Now, to get tongue weight, you need to weigh truck seperate, weight trailer axle plus trailer on front jack stand. now you can do the math with 2 equations for the actual tongue weight. (but basically, rear axle weight with trailer, minus rear weight without = tongue weight.) Its not perfect because it depends how level the frame is with the truck.
Another place that has scales are feed companies, logging companies, the dump, gravel pits, cement plants. Again, often you can see the scale reading or they will print a ticket and its not that steep.
Hope this helps.
Old Mar 6, 2006 | 08:23 PM
Mazatrol's Avatar
Mazatrol
Thank you scafes and mhoefer as well .
Old Mar 7, 2006 | 08:17 PM
maevans's Avatar
maevans
At the BP station in my home town, They will let you do a reweigh if you do it within a couple of hours, All for $ 8.00 Just tell them what you what to do.
Old Mar 7, 2006 | 09:38 PM
racsan's Avatar
racsan
i go to my local grain elevator after hours or on sunday, can read the display from the window.
Tugly
Dec 28, 2016 08:24 AM
Trx430ex
2014+ Transit
Nov 6, 2016 11:40 AM
meborder
All Things Towing
15
Jul 12, 2016 11:11 AM
Undercover Poe
All Things Towing
28
May 16, 2016 08:23 AM
1994F2507.3L
23
Apr 25, 2011 11:06 PM
