351w info
Old Mar 5, 2006 | 09:24 AM
orange peel's Avatar
orange peel
351w info
is there a website that lists all the information on the 351w? i tried to google it but didnt have much luck. im about to start putting mine together, as soon as i get a crank, and need to know what size rings and what not to get.
and for all yall that care im getting some AFR185s
Old Mar 5, 2006 | 09:39 AM
petes79f150's Avatar
petes79f150
IMO, this IS the website you're looking for. Did you have it bored and honed? If so, you'll need new pistons, and that will specify which rings you need. Same thing applies to the bearings. If you had any machine work done to the crank and rods, the bearings will have to match what they did. If you're getting all new crank, rods and pistons, they really need to be balanced. I guess what I'm trying to say is, a lot depends on what you did to the block, what NEW parts you're using, then we can go from there.
