4WD problem
Old Mar 3, 2006 | 10:10 PM
morabors's Avatar
morabors
4WD problem
I put the truck in 4WD the other day due to sleet and when I backed up 5 feet it felt like the brakes were being applied. Whats up? Thanks
Old Mar 3, 2006 | 10:38 PM
RangerPilot's Avatar
RangerPilot
What's your defintiion of applied? Like you couldn't move, it was pretty hard, or just a light drag? When's the last time you had it in 4WD?
Old Mar 3, 2006 | 10:51 PM
G BOBKA's Avatar
G BOBKA
Did you put in 4 wheel low? 4 wheel low is geared so low it might seem that the brakes are on.
Old Mar 3, 2006 | 10:57 PM
RangerPilot
Very good point.
Old Mar 4, 2006 | 01:15 PM
morabors's Avatar
morabors
It was not in low. It dragged plenty, almost to the point of not being able to move. I have only had the truck for 6 weeks, had it in 4X4 1 other time about a month ago.
Old Mar 4, 2006 | 01:21 PM
RangerPilot
Hm...assuming it doesn't do this unless 4x4 is engaged, I'd definetly check into the front end, starting with the transfer case and working forward. Something obviously is binding. Check the front diff fluid. The guys around here reccommend engaging it I believe once a month, whether you regularly use it or not, just to keep the system working nicely.
Old Mar 4, 2006 | 01:37 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Do you have the exact same tire size all around? Also, same tire size all around but having tires on one axle with a substantially different amount of wear than the other is not a good thing either. No need to jump into crazy stuff without starting with the obvious .
Old Mar 4, 2006 | 06:41 PM
morabors's Avatar
morabors
I'll check both ideas, thanks
