Plumbing Disk/Disk
Old Mar 3, 2006 | 04:51 PM
twisted56's Avatar
twisted56
Plumbing Disk/Disk
I'm ready to order all the fittings, valves (residual, adj.prop.) mounting hardware. I'm would like to ask for drawings/pics of just what order everything goes in. Where to order everything from? Part numbers would be very helpful. What size line?
Powerbooster/Master Cylinder under Cab.
Twisted
Old Mar 3, 2006 | 05:24 PM
Jag Red 54's Avatar
Jag Red 54
Hey twisted, call Sac Vintage Ford. Doug will sell you everything that you need and explain in detail about the residual pressure check valves. Good luck, Jag
Old Mar 3, 2006 | 08:57 PM
1low50's Avatar
1low50
I dont mean to bash anybody or any company but SVF is way overpriced on alot of stuff. If I remember right the residual valves are like 40 a piece and you will need two if your pedals are under the floor like mine. The adj valve is probably the same.It can all be found for much cheaper through Ebay and it can all be willwood products which are some of the best around. Heck find a local brake man and they can point you in the right direction and get you better parts for far less.
I bought my system through ebay and other online vendors but I went to a local store for all the fittings, line and rubber hoses. dont be afraid of some legwork and it will totally be seen in the price I think. Good luck either way.
Old Mar 4, 2006 | 12:51 PM
twisted56's Avatar
twisted56
Thanks.....I'll start checking around for some local supplies.
Younork
Mar 14, 2012 08:03 PM
UNTAMND
58
Jan 16, 2012 11:11 PM
arrowheadfred
Aug 6, 2011 01:07 PM
twisted56
Mar 28, 2004 08:18 AM
jwhjack
2004 - 2008 F150
Dec 12, 2003 12:42 PM
