f150 gear problems+
Old Mar 3, 2006 | 09:56 AM
rigit's Avatar
rigit
f150 gear problems+
well i have a 91 f150 v6 manual i was driven it the other day down a hill then all the sudden i couldnt do anything but brake when i reached the bottom and let it cool off i could drive it but i had to hold it in to gear but when i did that is smoked thro the stick area and im stumped and so are most of the ppl i kno there no grinding i didnt get a lift could it be the fluid need help thanks
Old Mar 3, 2006 | 10:22 AM
MustangGT221's Avatar
MustangGT221
Welcome to FTE!
First, your 6 cylinder engine is an Inline engine, not a V style engine.
Second, I'm having a hard time understanding what happened, could you elaborate?
What did you mean by "all of a sudden I couldn't do anything but brake"?
The more detailed you are the better we can understand you
Old Mar 3, 2006 | 11:12 AM
rigit's Avatar
rigit
well it wouldnt go in to gear not unless u held it and now after that time u have to hold it into gear to drive but if u do that it smokes outa the stick area and im just tryin to fine sumone who could tell me if it was the clutch tranny or if a fluid change would do the trick
Old Mar 3, 2006 | 11:35 AM
Kemicalburns's Avatar
Kemicalburns
sounds like the synchros may be shot, the fluid needs changed and the clutch needs replaced
Old Mar 3, 2006 | 12:39 PM
rigit's Avatar
rigit
thank u all
