59-60 truck diffrences
Old Mar 3, 2006 | 01:01 AM
60'BigBlue's Avatar
60'BigBlue
i am consdering buying a f750 but my question is how can i tell the if it a 1960 or a 1959 the vin tag is ripped off and i was wondering if theres an easier way to tell than down on the frame rail. like where the wirs come out what engine it has transmission eomething along thos lines
it has a llincoln yblock(think a 302 not a 100%sure) transmatic automatic tranny power steering other than those i cant think of any thing else thats special about it. any help would be apreciated
Old Mar 3, 2006 | 02:09 AM
Col Flashman's Avatar
Col Flashman
Is the VIN Plate that you stated is missing, what is known as the DATA Plate that is on the inside of the Dispatch/Glove Box Door or Mounted on the Drivers Door Frame in the Cab?
The engine will either be a 292c.ier or a 312c.i.er, (look for a heat exchange pipe that is connected to the exhauste manifolds & crosses around the front of the engine to attach to both manifolds), if it is the Original engine, as the 302c.i.er is a product of the Mid to Late '60s.
I've seen the VIN #'s stamped into the Radiator Support & on the Firewall on the Passenger Side, try there.
The Hood of a '59 has an Cut-Out in the Front where there is a Mesh Screen that has "FORD" letters bolted in place.
The '60 Hood is Slotted on either side of the FORD Hood Badge which has 3 points @ the top of it similar to a Crown, 2 on each Side w/ 1 in the Middle & the Grille is a Rather narrower than the '58s or '59s Grille.
Old Mar 8, 2006 | 12:52 PM
Gerald Osting's Avatar
Gerald Osting
Colonel Flashman,
You sound like you are the guy who knows about 57-60 Ford trucks. I just purchased a 1960 Ford F250. It is pretty much all original as much as I can tell. I'm looking to update the brakes to discs and add power steering. Any thoughts? I've already purchased a large bottle of aspirin!
Gerald
Old Mar 8, 2006 | 02:32 PM
cbrudi's Avatar
cbrudi
converting your brakes to disk
Try Sacramento Ford. They have a large segment on conversion parts, including brakes etc.
I am looking into this myself for my 1960 F100 (4x4), but they do not list anything for the four wheel drives yet.
Regards
Old Mar 8, 2006 | 03:50 PM
Col Flashman
Originally Posted by Gerald Osting
Colonel Flashman,
Gerald
I've collected as many books from the era printed by FoMoCo & Vendor companies as I am able, as well as some that have been printed recently to fill in the gaps & I'm still adding to my collection from both sources.
Please create your Gallery so that we may view your "Olde Girl".
Power Steering, I'd stay w/ the original Ram Assist, fore it Bolts right up to Our trucks Steering system & contact John @ John's F-Funhundred in Anaheim, CA. https://www.johnsf100.com/5766shop/index.htm, just tell him I sent you he'll treat you right.
Other dealers have the same kit for varying prices & you still have to supply the P/S Pump & bracket yourself.
Now some will tell you to go w/ the T&@#%a 4x4 P/S system, but the end of your Steering Column has to be Hacked Off & Knuckle has to be Welded on the end of it in order to accept the system properly.
You also loose the use of the Horn Button that came w/ your truck as the orignal shaft is hollow that the H/B wire runs through & it no longer can.
The Steering Column also has to be Re-set in order to work correctly.
I'd also stay w/ the Drum/Drum set-up & have a machinest drill drain-holes in the drums to let the water drain & the shoes dry out more quickly when you've to drive through standing water.
Add a Dual Brake Master Cylinder for safety reasons, '68-'72 Mustang is what I believe has been used successfully.
Then track down a Midland P/B Booster as it was Original equipment option for our trucks, it mounts on the Frame Rail under the Driverside.
I found the Parent Company on the Net easily by just doing a search for Midland Power Brake Booster.
The modern up-dated systems that others here recommend are just detracting from the engine compartment looks & takes Up way to much space inside the compartment & usually has issues w/ encroachment on the inside of the compartment w/ already established components.
I believe we all have @ 1 time or another purchased Asprin for the same reasons, @ least it helps keep the blood thin & flowing freely.
Old Mar 8, 2006 | 04:35 PM
Gerald Osting
Colonel Flashman,
Unbelievable! I know now I've run into the the right web-site. Thanks for all the information. I'll need to digest it and do some looking around for parts. That should develop another round of questions. Unfortunately, this thing they call a job gets in my way of spending more time on what I can see as a growing passion.
I'll try an post some of the pics over the next couple of days.
I also want to thank cbrudi for the referral. Every bit helps!
Have a good day!
Gerald
Old Mar 8, 2006 | 07:06 PM
angus's Avatar
angus
According to the "1960 Ford Trucks Full Line Folder" models above the F600 had the better-looking 1959 style grill, with 3 round openings in the panel below the grill. So it would be easy to mistake a 1960 for a 1959.
I say call it a 1959; the '50s sound cooler.
Old Mar 8, 2006 | 07:42 PM
mr4speedford's Avatar
mr4speedford
Do you see any part #'s begining with C0TF?=60 if all you see is B9C or B9TF- then well you get the picture.... Ford also started using fuse panels in the wirring in 1960. The back of the insturment cluster is dated as well as the heater box holder on the the back....
Old Mar 8, 2006 | 09:29 PM
60'BigBlue's Avatar
60'BigBlue
bolth 1959 and 60 have the 600+ have the same body and front end this one has the factory hood scoop and ram air type air cleaner i am absoulty sure this is the orginal lincoln 302 motor and i did find the vin number it is a 1959 750 with a 302 linclon.
Old Mar 8, 2006 | 10:45 PM
Col Flashman
Speed, your books are more handy than mine, please take a gander @ them as we've not gotten anywhere near being able to un-pack them from the move to our new home.
I've never even heard of a 302 Lincoln, let alone seen it listed in any for the FoMoCo Lit.
Old Mar 9, 2006 | 12:32 AM
60'BigBlue's Avatar
60'BigBlue
the lincoln 302 is in my 1960 ford truck shop manual
the vin # of the truck is (i may of missed a number not sure)
f75n9v16848
n=302 v-8 4 barrel
