fuel problem
Old Feb 26, 2001 | 10:06 PM
madcow's Avatar
madcow
fuel problem
Hey all. I have a problem i hope someone can help me with. When i went back to my truck after being parked for hours, a 71 f250 camper special, gas was dripping out of the filler neck. It popped the filler cap half off. This was really weird. I thought someone had syphoned my gas. Did they? Or is my vent clogged? Any ideas?
oh i forgot to mention it was the tank behind the seat.
Old Feb 26, 2001 | 10:17 PM
FE427TP's Avatar
FE427TP
fuel problem
was it a hot day? and had you just refilled your gas tank? if not either of those then buy a locking gas cap for your truck, I know they make them
Old Feb 26, 2001 | 11:08 PM
1970 camper special's Avatar
1970 camper special
fuel problem
My 70 f250 will do the same thing when you have a full tank of gas and its hot out side, or the truck is parked funny. Never had the gas cap blow off though!!!!!! You might consider getting a new cap because I believe that is where the tank vents excess pressure from, maybe that's why it blew off, not venting right?
Good Luck
Brian
Id rather push a Ford than drive a Chevy,..but you never have push a Ford!!!
Old Feb 26, 2001 | 11:54 PM
madcow's Avatar
madcow
fuel problem
the day started out cold but warmed up when the sun came up. thats when it started leaking. and yeah the tank was pretty full. but it seems strange it just started doing this. it never did it before. i'll get a new locking cap and see what happens.
Old Feb 27, 2001 | 08:38 AM
fozzy's Avatar
fozzy
fuel problem
I have had the same trouble, so Im keeping up with your post to see what to do.
GOOD LUCK!!!!
Old Mar 11, 2001 | 04:21 AM
madcow's Avatar
madcow
fuel problem
Hey guys. Just an update. I didn't buy the new cap cause i'm unsure if its safe. I noticed the fuel would come out of the neck without the cap. if i get a tight cap what would happen to the pressure? i don't want the gas tank exploding right behind my seat.
Old Mar 11, 2001 | 06:28 AM
jowilker's Avatar
jowilker
fuel problem
Ed I was first aware of that problem when I was a boy, and with trucks older than 71. If the tank is full or nearly full and is parked with the drivers side lower than the passenger, the sun can warm the cab and draw the gas up and out of the filler neck.
To compensate never fill the trucks tank full is you aren't going to drive out 4-5 gallons of gas, park the truck with the drivers side higher, I have pulled the left rear on top of the curb to get the angle. As far as I know their is no danger of explosion. I have never heard of a behind the seat tank exploding and burning. The rubber between the tank and filler can go bad and you can smell gas inside of the truck. New rubber will stop that.
Follow those guidelines and enjoy your truck.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Mar 11, 2001 | 06:34 AM
Nathan's Avatar
Nathan
fuel problem
Your gas tank wont explode, the pressure will vent through your carbs needle and seat, filling the cylinder up with fuel! Been there! You must have a vented cap. Remember, the fuel you fill up with comes from tanks stored under ground, so its about 55-60 degrees when you buy it. Then it heats and expands in the tank and runs down the side of your truck The best fix? Make sure you fill the tank when you know you will be running a gallon or two out before its parked, and park so the filler neck is higher. This allows air to ecape instead of being trapped on the other side of the tank. Ive thought about this alot because Ive had to touch up paint too many times. Theres just no better answer.
Nathan
Old Mar 11, 2001 | 04:07 PM
chenders's Avatar
chenders
fuel problem
These trucks do not vent through the cap, there should be a line that travels down through the frame to the canister filter, which sits near the front passenger's side underneath the radiator core. Check to make sure this is not plugged.
Old Mar 11, 2001 | 05:38 PM
madcow's Avatar
madcow
fuel problem
>plugged.
I did a quick look under the engine compartment and couldn't find a charcoal cannister. my truck is a 71 ford f250 with a 360. anyone know if it came with one from the factory this year was it mandated later on? Maybe mine was removed.
Old Mar 11, 2001 | 05:46 PM
Jigsaw's Avatar
Jigsaw
fuel problem
