Is there a Kit for Power Steering Setup?
Old Mar 2, 2006 | 01:01 PM
lakecityg's Avatar
lakecityg
If so can you tell me where I can get one? one that is not to tough to install?? and price??
Old Mar 2, 2006 | 02:03 PM
Goobzilla's Avatar
Goobzilla
Mid-Fifty and other vendors have a complete kit for the Toyota PS swap. You need a 79-mid 84 Toyota 4x4 PS box like this:
Ferguson777 (if he's feeling up to it) can e-mail you a copy of the tech article on the swap or I can send it after I get home tonight. It's a pretty easy install, and the cost isn't that bad. The kit is about $249 Bracket, Pitman arm & U-joint. You'll still need hoses plus the cost of the box.
Old Mar 2, 2006 | 02:54 PM
lakecityg's Avatar
lakecityg
yes. if you don' t mind please send me the tech article as soon as you get a chance. thanks!
Old Mar 2, 2006 | 03:02 PM
Goobzilla's Avatar
Goobzilla
Can do! Are you going to keep your stock steering column?
Old Mar 2, 2006 | 05:23 PM
lakecityg's Avatar
lakecityg
honestly i have no idea? i am 100% new to this so any advice will help. whould i keep it? if not is there a certain one i want??
Old Mar 2, 2006 | 05:30 PM
Earl's Avatar
Earl
Read through the tech article and you should have a better idea of what's involved. That will help you ask questions so you end up with what you want.
Goobzilla's Avatar
Goobzilla
Do a search for steering column. Most choices are stock, Ididit/Flaming River (GM Based), or a salvaged GM column. I like the 77-81 Chevy Van column (good length, tilt, no key on column).
Old Mar 2, 2006 | 05:40 PM
Col Flashman's Avatar
Col Flashman
This is the Set-up that requires you to hack the End of the Steering Column OFF so that that Knuckle you see in the Picture can be attached. The placement in my experience interfers w/ the Header & you loose the Use of your Horn Button on your Steering Wheel.
Contact John @ John's F-Funhundred, https://www.johnsf100.com/5766shop/index.htm, for the Original Type of P/S system that Just bolts right into place w/o Hacking or Cutting or Welding a Bleedin' thing, it was available for our trucks as an Option back in the day & tell him Colonel Flashman sent you.
There are other Companies that Sell the Same product for varying prices, I just find John a lot easier to deal w/.
Old Mar 2, 2006 | 05:44 PM
lakecityg's Avatar
lakecityg
thats what i'm talking about. i wanted something that would bolt right in. thanks man!!! and also, this is the truck i just purchased. any opinions?? http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Mar 2, 2006 | 05:59 PM
theGman's Avatar
theGman
I happen to have for sale at half price a nearly new alternate ps unit...the bolt on slave cylinder style, which is also sold by many vendors. This enables you to keep your stock steering box and column, etc. since all connections are done down in the tie rod area.
Paul
Old Mar 2, 2006 | 06:07 PM
lakecityg's Avatar
lakecityg
u got any pics?? is that everything that i will need??
Old Mar 3, 2006 | 03:11 AM
Col Flashman
Old Mar 3, 2006 | 05:57 AM
reamer's Avatar
reamer
Is the original question for 48 - 52? 52 and newer?
F-1 or F-5 or F-8?
It's all in the details.
Hmmm will the power assist work of an F-5?
Reamer
Old Mar 3, 2006 | 08:36 AM
lakecityg's Avatar
lakecityg
its for a 1954 f-100
Old Mar 3, 2006 | 02:35 PM
Col Flashman
its for a 1954
f-100
This is from John's '48-'56 Page.
