Sponsored by: Real Truck
another auto hub queston...
Old Mar 2, 2006 | 09:49 AM
rockcity's Avatar
rockcity
OK, so I swapped out my auto hubs with Warn Premium hubs
My question: Do I need to block off the vaccumn lines or can I just leave them connected???
Thanks,
Rob
Old Mar 2, 2006 | 10:14 AM
Fords4Me's Avatar
Fords4Me
Oops! Accidental post.
Old Mar 2, 2006 | 10:23 AM
Big Orn's Avatar
Big Orn
Check out this thread:
https://www.ford-trucks.com/forums/s...d.php?t=467258
It's the only way to go, imo. Or should I say - that's how I'd do it.
Old Mar 2, 2006 | 10:39 AM
Fords4Me's Avatar
Fords4Me
do they cause a vac leak when you go to 4wd? i would disconnect them.
Old Mar 2, 2006 | 04:11 PM
BFR250SD's Avatar
BFR250SD
Rob,
Welcome to FTE!
Defintely block off the vac lines. They'll still be applying vaccum to the hub area when you go to 4x if you don't. While this won't casue any immediate harm, it "can" cause the seals to eventually fails causing you to bring in some unwanted junk, or worse cause your A/C controls to act screwy if you do get a leak in those lines.
For each side: 1/8" x 1" machine screw, a 3/16" vacuum cap and 2 wire ties and you'll have no worries.
