davh Expedition 00
Old Mar 2, 2006 | 09:06 AM
davh's Avatar
davh
davh Expedition 00
How do you reset the anti-theft and if it is a Dealer only does anyone know how much it should cost?
Thanks, Dave
Old Mar 2, 2006 | 09:07 PM
High_Horse's Avatar
High_Horse
Try doing a "search" using anti-theft reset....plus, I believe, but not positive, that your owners manual tells you how also?
Old Mar 2, 2006 | 10:05 PM
FTE Herman's Avatar
FTE Herman
Welcome to FTE davh! What do you mean by reset? When you turn the key to the 'on' position do you see the 'Theft' light flashing? If so, can you try another key?
Old Mar 3, 2006 | 06:52 AM
davh's Avatar
davh
My 2000 Expedition will not start periodically, whether I try another key or not. The manuel does not give instructions on resetting when this happens other that see your dealer. I have to just wait it out and finally it will start. I was told that the anti-theft has to be reset at Ford but was wondering if someone had had this similar problem and found another cure.
Thanks, Dave
Old Mar 3, 2006 | 03:39 PM
FTE Herman's Avatar
FTE Herman
I'm sorry about that. There's noting I know of to do a reset. Do you by chance have a reemost starting system on the vehicle? If so, I've seen their PATS bypass have fits from time to time.
Old May 16, 2006 | 07:31 AM
davh's Avatar
davh
I still have not found the problem of my 2000 Ford Expedition not starting. I have been told it is a PATS anti-theft problem but that is all. It will work perfect for a while then you go to start and it will not turn over. It seems that everything works but the radio and CD player. If you leave the key on and wait for the radio to come back on which could take over an hour then wait a few minutes it seems to reset and will start cranking and start. Has anyone had experience with the transponder ring which reads the vehicles key?
Old Aug 22, 2006 | 08:02 AM
davh's Avatar
davh
Will the after market cold air intake systems and MAF help hp and mileage on my 2000 Ford 5.4 Expedition? After reading some of the posts changing the exhaust system seems to be a more noticeable change. Thought?
Old Aug 22, 2006 | 01:06 PM
pdqford's Avatar
pdqford
davh,
Did you get your PATS problem resolved?
Old Aug 22, 2006 | 02:19 PM
davh's Avatar
davh
yes, it was actually a starter relay on the firewall.
Old Aug 22, 2006 | 04:26 PM
pdqford's Avatar
pdqford
Wink
And what was the clue that led you to the starter relay . . .
