trans help
Old Mar 2, 2006 | 07:30 AM
renchr56's Avatar
renchr56
trans help
I have a 96 explorer. About a month ago the trans developed a shudder while going into od. It doesn't do it in any other gears. It only lasts until it gets into od. Any suggestions. I changed the fluid abot 17000 mileas ago. Is it possible to use the merc v to see if that takes care of the shudder?
Old Mar 2, 2006 | 09:25 AM
marragtop's Avatar
marragtop
Have you pulled the codes? There may be a code stored even though the CEL isn't on.
Old Mar 2, 2006 | 10:31 AM
renchr56's Avatar
renchr56
I forgot to mention , there are no codes.
Old Mar 2, 2006 | 05:47 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Renchr56, yes I'd try the Mercon V. It was developed specifically to address this OD shudder. If you have a suction pump, you can do an exchange, drive it to mix, then do a couple other exchanges. Or you can do a drain using one of the cooler lines, while adding 2 quarts at a time. Don't let it run dry.
LubeGard in the Red bottle is a good additive, if you want to try it. I use it in my 5R55E (2000 Explorer).
TLR
Old Mar 3, 2006 | 04:50 AM
renchr56's Avatar
renchr56
I will try to exchange the fluid this weekend. That is if I can get mommas car from her.lol
