Help - Broken Hood Release
Old Mar 1, 2006 | 11:19 PM
joeglow's Avatar
joeglow
I drank an energy drink and broke the hood release handle right off on my 84 F250. It was always a tough one but now I've broken it.
Does anyone know how to get the hood open? Should I just yank on the cable? I've learned my lesson - apply WD 40 liberally to these old beasts.
Thank,
joe
Old Mar 2, 2006 | 04:51 AM
srercrcr's Avatar
srercrcr
Yanking on the cable will probably only be yanking on the sheathing...the inner wire won't budge. Let's see if someone has any ideas. Try searching also.
Old Mar 2, 2006 | 05:25 AM
Dungeon_Master's Avatar
Dungeon_Master
Remove the grill.Use a screw driver and some muscle to pry to part the wire where it hooks too. Towards the drivers side it should unlach.Then replace the needed part and spary it up with some grafite or white lithum spray. if it's just the handle and the bar it clips to is there a pair of vise grips should work.
Good luck. I had to do it last year to one of my trucks . It broke off at the latch on mine.
Old Mar 2, 2006 | 06:18 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Joe to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 2, 2006 | 06:23 AM
LargeMarge's Avatar
LargeMarge
I broke the hood release cable on my f250 last week. Srercrcr is right about yanking the cable only pulling on the outer sheathing. On my truck I took the inner panel off inside the cab and used a pair of wire strippers to strip off the outer casing exposing the actual cable. With the cable exposed I simply used a pair of needle nose vise grips and pulled the cable, the hood popped open. Then it was just a matter of removing the broken cable and getting a new one at the junkyard for 10 bucks.
Old Mar 2, 2006 | 08:38 PM
NavyMIDN08's Avatar
NavyMIDN08
i'd have to agree with just stripping the outer sheathing, it'll save a lot of time and heartache, unless you snapped it off way under the hood. even then, you may be able to reach under the core support and grab the wire and strip it that way. its a lot easier than removing the front facia
Old Mar 5, 2006 | 02:46 PM
joeglow's Avatar
joeglow
Thanks everyone. My frind Pete was in town and he thought of the stripping the cable and vise grip thing too. It pooped right open. It's a lot easier than that old handle.
Now I just have to figure out how to reattach some sort of handle to that cable w/o welding. I don't think superglue is gonna work.
Old Mar 5, 2006 | 03:29 PM
Dungeon_Master
Napa sells a new one for $23.00 probably pick one up at a junk yard for $5.00 or $10.00
Old Mar 5, 2006 | 04:10 PM
NavyMIDN08's Avatar
NavyMIDN08
if you want a cheap handle, you could probably get a cable clamp at the hardware store. install a washer (with a hole small enough to not slide over the clamp) and you will have a simple, cheap handle.
Old Mar 8, 2006 | 05:36 PM
Nathane's Avatar
Nathane
does the term "getto" mean anything to you???
just get the handel, and a new cable since youve allready trashed it. Put some grease on the inner cable, and relube every year
~Nate
Old Mar 8, 2006 | 07:59 PM
NavyMIDN08's Avatar
NavyMIDN08
well, its actually "ghetto," and for the guy on a low budget, or keeping a work truck in operating condition, there's nothing wrong with a little bit of southern ingenuity. yeah, it may not be a restoration quality repair, but not all trucks are show trucks either... I'm sure most people on this forum would admit to a few shadetree-mechanic repairs just to make it to the next paycheck, i know i have.
Old Mar 9, 2006 | 09:57 PM
Nathane's Avatar
Nathane
spending $5 on a temporary fix that only should cost $15 is stupid though...
I saw a kit at the local farm&barn for $14.99... Made by either "HELP" or leslie... New cable, and a new handle... granted its not a stock handle either... you could get that (or something really close) in the same section... "HELP" or "leslie"
good luck
~Nate
