I have an 03 7.3 sd the high beams no longer work if you use the flash to pass nothing if headlights are on low beam push to highbeam nothing the headlights go out anything will help thanx.Marc
good one.would not be the first time i saw both bad at one time,
I had this happen twice on my '02. I had the old style 6x9 removeable bulbs.Once was the low and about a year later was the high. Both times it was right in the middle of pothole season!!
I am having the same problem with my '00. the high beam fuse keeps burning out as soon as I turn the high beams on. Any ideas were to start looking, do you think it is a break in the wire somewhere?
Thanks for any help
Thanks for any help
Sounds like it's time to start tracing the wires. I'd start up at the headlights and trace them back. There has to be a cut wire somewhere along the path that's causing a dead short. Electrical problems aren't that hard, they're just very time consuming. Have patience and good luck.
thanks for the info, I am not very good at electrical, but do all of my own mechanical work.
