Try removing the wire to the sending unit, take a paper clip or a piece of wire and put it in the terminal. Turn the key on and have someone watch the guage. Touch the clip to the engine momentarily and see if the guage pegs. If it does, then try replacing the sending unit. If not, check for power, loose wires and bad connections. Wiggle some things around with key on and someone watching the guages.
