valve timing?
Old Mar 18, 2001 | 11:36 AM
rob73f250's Avatar
rob73f250
valve timing?
Here are the facts that bring me once again to this great group.
73 F250HD Camper Special.
460CI running points and coil.
Ignition Timing at about 10 degrees(provides best"keep running idle")
Slow to start...have to feed the gas and crank unless engine is warmed up.
Good power and acceleration over the full RPM range.
There are no air leaks around the intake manifold or carburator.
At idle NO VACUUM reading at the intake manifold.
At RPMs above idle vacuum gauge reads steady at around 10in/hg.
Idle jet screws set at 1.5 turns<>.
Idles like a 1/4mile dragster(lopes)
Compression within 5lbs. of 130lbs. for all cylingders
OK the no vacuum at idle and low vacuum at speed leads me to believe that...
1. The timing chain has jumped a tooth? So anyone out there have and easy way to prove valve timing without pulling the whole front end off the truck and engine?
OR
2. Sometime in the past an RV type cam has been installed?
3. It is something else that I am not or I forgot to check...(it usually is)
Thanks in advance for the input..
ROB
Old Mar 18, 2001 | 07:45 PM
thenkel2's Avatar
thenkel2
valve timing?
Try a compression test to see what the cranking compression is and has anyone adjusted the valves lately? If the valves are adjusted to tight it will cause similar problems.
Old Mar 18, 2001 | 10:03 PM
77_F150_4x4's Avatar
77_F150_4x4
valve timing?
RIchard Chapman
Nov 23, 2013 10:28 PM
jonmark1985
Jun 25, 2013 05:53 PM
bigwalt1
20
Jun 18, 2010 08:11 PM
Jodell
Mar 5, 2009 08:23 PM
chuckj5
May 8, 2004 07:33 AM
