351 Knock
Old Mar 1, 2006 | 12:24 PM
newt79-99's Avatar
newt79-99
351 Knock
I just recently purchased a 79 F-150 with a 351m. It has a knock at warm idle but not when cold. I am thinking that it will need rod bearings. Please point me in the right direction. Thanks!
Old Mar 1, 2006 | 01:18 PM
garypettengill's Avatar
garypettengill
Because the crank is iron and the rods are iron they would heat at approx. the same rate so if a rod bearing is bad it will probably knock both cold and warm. On the other hand, pistons are alum. and heat at a different speed and rate. Good possibility it's a wrist pin. It's a rebuild either way. Get a 400 crank and pistons and you will have a much torqueier(is that a word?) engine.
Old Mar 1, 2006 | 05:08 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome newt to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 2, 2006 | 09:15 AM
Bill_Beyer's Avatar
Bill_Beyer
Best way I've found to pinpoint a knock in a specific cylinder is to "short out" each cylinder 1 at a time by pulling the plug wire while it's running. When you pull the wire on the cylinder that's giving you the problem the knocking should either quit or change significantly.
If it doesn't quit/change after you've tried all of the cylinders then it could be a main bearing or it's not in the bottom end at all.
Old Mar 2, 2006 | 01:10 PM
likethefords's Avatar
likethefords
My old 351M did that as well, when it warmed up it really rattled and finely through 2 connecting rods right through the oil pan and thrashed the block. So if you want to save the motor try not to run it too long like this. I think it would be a rod bearing myself.
Old Mar 4, 2006 | 07:20 PM
maples01's Avatar
maples01
Mine did this shortly after I bought it, I had to get my crank turned to clean up the damage, bearings were shot, oil is thicker when cold.
Old Mar 22, 2006 | 08:36 AM
newt79-99's Avatar
newt79-99
Well I dropped the oil pan and 7 rod bearings were worn out and one was spun. I replaced with a 400.
Old Mar 22, 2006 | 03:21 PM
tastyklair's Avatar
tastyklair
Did youi just replace the crank and pistons? Glad you found it. Sorry it was serious.
Old Mar 23, 2006 | 06:07 AM
newt79-99's Avatar
newt79-99
I got a good deal on a 400, so after I dropped the oil pan and found the carnage, I just pulled the motor and it is sitting in the corner of the shop.
P.s. Where in Eastern PA are you, I just recently moved to Lancaster county
Old Mar 23, 2006 | 12:32 PM
tastyklair's Avatar
tastyklair
Just below Allentown.
