Wheel Hop
Old Mar 1, 2006 | 12:17 AM
gearhead351's Avatar
gearhead351
Red face Wheel Hop
I have a 1984 Ford F250 4x4 with a 351 Windsor. I have really bad wheel hop and I know what causes the wheel hope as far as the leafs winding up. What kind of cheap traction bars would work? How long would they have to be to work good? Thanks
Old Mar 2, 2006 | 01:45 PM
Pkupman82's Avatar
Pkupman82
I picked up a set of Superlift traction bars from Bronco Graveyard for $190, money well spent. I am running them on my 84 F150 with a 4" lift and 33s, as long as they are adjusted correctly they work awesome.
Old Mar 4, 2006 | 09:36 PM
southernracer89's Avatar
southernracer89
i have the same problem. is there thing any out there for a truck with the stock lift? i drive an 86 f-150 4x4 and the wheel hop from the new 5.0L HO motor is down right horrible.
Old Mar 5, 2006 | 08:18 AM
8 Lugs's Avatar
8 Lugs
Install a 2" "add-a-leaf" to firm up the rear spring (this should not change the ride quality much)
Omit the 2" factory block to bring the leaf spring closer to the axle.
Your ride height will not change
This should cure the wheel hop and cost about $50 bucks.
Steve G.
351Cleveland C4
24
Jan 13, 2015 08:25 PM
BigBlkEX
Apr 28, 2014 07:23 PM
brokeisnojoke
Jun 29, 2011 10:29 AM
countryboy69
Jan 14, 2011 06:02 PM
Mike SVOR
Oct 17, 2007 09:05 AM
