78 front axle questions
Old Feb 28, 2006 | 10:55 AM
cowboyty's Avatar
cowboyty
Question 78 front axle questions
A friend and I are each working on 1978 f250 pickups. We are looking for a front axle either a dana 60 or dana 44. It had a dana 60 under it but previous owner sold it and hasn't replaced it. I am having problems finding a 3/4 ton front axle for it and didn't know if a 1/2 ton axle would fit or not. We are located in southwest Iowa.
Old Feb 28, 2006 | 11:33 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
How much do you want to spend? Im sure Hansens Truck Salvage in Omaha has what you need but they are a little expensive.
SFCWhitaker's Avatar
SFCWhitaker
Cowboyt, The biggest difference in that a 250 has 8 lugs and a 150 has 5. second is the gear difference. total different setups alot f150s have coil springs were f250 have leafs do to the fact heavier duty truck. Try looking for a f350 4x you could swap that one because its is also HD. Also a lot of salvage yards have acess to what they call a hot line, it goes all over maybe they can get it from some where else if you cant find one locally. Hope this helps
Old Feb 28, 2006 | 12:14 PM
cowboyty's Avatar
cowboyty
hansens don't have anything already checked there, but thanks. And I will talk with the local salvage yard to see if they can find anything for us.
Old Feb 28, 2006 | 12:19 PM
Mil1ion's Avatar
Mil1ion
Have you checked the classifieds or posted in the Chapter forum closest to you ?
This is more of a discussion forum
There are also online wrecking yards that can been seen on google
Welcome to the site.. btw
Old Feb 28, 2006 | 12:47 PM
highboy390fe's Avatar
highboy390fe
Ebay always has them on there. Check some of them out.
Old Feb 28, 2006 | 02:33 PM
1975Ford's Avatar
1975Ford
Check the fourwheeler magazines, they have them there too. Try the sponsor on the left side.
Old Feb 28, 2006 | 03:31 PM
MBBFord's Avatar
MBBFord
Check junkyards in a 30 mile or so radius from you, someone should have a 73-79 F-250 or 350 4x4. If you found a 79 F-350, all the better, b/c it would be a D60, and most F-250s had a D44 HD, and don't remember what option or package changed it to a D60
Old May 30, 2006 | 02:35 PM
cowboyty's Avatar
cowboyty
My friend purchased a Dana 44 frotn axle, but its missin the pasenger side hub, rotor, and caliper. He ordered parts for it from local parts store but the rotor was not the right one. The other side has a heavy spacer pressed onto it and not sure where you can get one of those or if there is an interchange we could use. I'll try to get some numbers off it tonight and put on here tommorrow to help us out.
Old May 31, 2006 | 06:19 AM
cowboyty's Avatar
cowboyty
here are the numbers i found on the axle housing (44-9F) (C38561).
Old May 31, 2006 | 08:07 AM
1975Ford's Avatar
1975Ford
(44-9F) translates to and Dana 44 with 9 inch ring gear.
Those numbers where stamped into the housing.
What are the numbers on the metal tag mounted on the front cover?
Old May 31, 2006 | 08:17 AM
cowboyty's Avatar
cowboyty
The tag on the front cover was missing.
Old May 31, 2006 | 08:23 AM
1975Ford's Avatar
1975Ford
Items you need to check the rear and front gear ratio.
  1. Duct tape
  2. Rope, string, or ribbon.
  3. Flat driving surface.
On driver side tires, where the tire make contact with the flat driving surface, place a strip of duct tape.
Then place a some duct tape at one end of the rope (or ribbon, etc..., or something that will wrap around the driveshaft) and tape it to the very bottom or the very top of the driveshaft. Then drive the truck forward until the tire make one complete revolution. Then count the number of times the rope has wrapped around the driveshaft PLUS the amount the tape has rotated from where you started. For instance, If rope was taped to the very bottom of driveshaft and the rope wrapped around 3 times plus now the tape on driveshaft is facing at the very top of drive shaft (the driveshaft has turned half a turn). 3 rev plus a half turn = 3.50:1 gear ratio.
Check if front axle gear ratio matches the rear axle gear ratios.
Old May 31, 2006 | 08:45 AM
cowboyty's Avatar
cowboyty
The parts I am not sure about is the rotors he got for them did not match the one on the axle. The rotor on the axle looks like this one witha pressed spacer with the studs through it.
[/img]
Old May 31, 2006 | 09:10 AM
1975Ford's Avatar
1975Ford
When you purchase the rotor, purchase a new rotor and hub assembly, the assembly is sold as a unit and will cost less than buying each separate part.
