How difficult is it?
Old Feb 27, 2006 | 08:03 PM
Modified's Avatar
Modified
Do any of you fine ford loving folks know how hard it is to install a/c in a non a/c truck? Are there aftermarket parts (complete set ups) available or should I go to the bone yard? Also would late model configurations work on a 78 F250?
T.I.A!
Old Feb 27, 2006 | 08:56 PM
Mil1ion's Avatar
Mil1ion
Topic should be in title
There are numerous threads relating to this topic.
Maybe search the titles with Air Conditioning Swap in them ?
*Note:
If you have a donor truck it's a lot easier.
The hardest part is cutting the Huge hole in the firewall.
There are dealer option AC units that fit under the dash as well.
Old Feb 27, 2006 | 09:22 PM
pcheyne's Avatar
pcheyne
I instaled it on my 77 f100. Got all the parts from a wreacking yard for $100. I used a piece of cardboard to make a template of the hole in the firewall.
Old Feb 27, 2006 | 09:29 PM
condolan's Avatar
condolan
I don't know anything about installing A/C into a truck that never had it originally, but it's worth mentioning that it took a good weekend for me too take my heater/AC box out from under the hood to replace the heater core. Man was that annoying, I had to remove a valve cover and all the small stuff around it, and the I chopped a couple of bigger holes into my firewall just so I could pull it out. Heater worked great after I was done though. A/C still don't work on my truck. Like pcheyne pointed out though, it's a lot cheaper to buy stuff from the junkyard (considering it works of course).
Old Feb 27, 2006 | 09:40 PM
Mil1ion's Avatar
Mil1ion
I forgot to mention you will need a different dash, vent tubes, dash switch,wiring, front coil springs ,etc.
The list is a long one.
That's why I suggest a donor truck
Old Feb 27, 2006 | 10:48 PM
fp_5's Avatar
fp_5
Condolan, I wrestled with the heater core just like u did the first time. Second time around I read the tech article here on FTE and did the whole thing from the inside of the truck. Wasn't the most fun I've had but I was done in a couple of hours.
Old Feb 28, 2006 | 10:20 AM
MBBFord's Avatar
MBBFord
Mil1ion, he wouldn't have to install new front coil springs.
I mean, the whole a/c system won't weight over 100 pounds, and wouldn't even make them sag any.
I know there are spring for non-a/c trucks and springs for a/c trucks, but still that's a good bit of extra work that isn't needed.
But yes a complet parts truck would be the thing to have.
Even if the body was complet cra*, not much to the truck, but had all the a/c stuff, it shouldn't cost more than about $200 for the whole thing, and what you don't use(if you want), you can part out the rest of the truck, and get at about your money back.
Old Feb 28, 2006 | 05:00 PM
Modified's Avatar
Modified
I have a 78 f250 supercab so I think the springs shouldn't be an issue. Heck I never springs were different for a/c / non ac
Old Feb 28, 2006 | 05:45 PM
draglink's Avatar
draglink
I would just buy an aftermarket kit. Try Vintage Air, or go to www.ackits.com.(click on Ford truck & van). I put one of their kits in my 76' Bronco....worked great!
Old Feb 28, 2006 | 05:52 PM
Franken-Truck's Avatar
Franken-Truck
Get one of the cheapy 5000 BTU window units and hang it in the rear sliding window of your truck. Seal it with some duct tape. Run the chord into a power inverter like those used in motor homes, and then maybe upgrade your alternator to handle the extra draw Your windows will frost over
And if you have to ask, no I'm not being serious. . .or AM I?????
Old Feb 28, 2006 | 05:59 PM
Modified's Avatar
Modified
That was Funny! Thank for the aftermarket link. I'll check it out!
Old Feb 28, 2006 | 06:12 PM
havi's Avatar
havi
I'll have the Roast Duck
I used a 7500 btu AC unit, w/plexi-glass surrounding it to fit the side window in my 79 bronco. Inverter and bigger alt. and dual batteries too. Only problem I experienced was I had to keep the defroster on high all the time. This annoyed me because I couldn't hear the 8 track player.
Old Feb 28, 2006 | 06:30 PM
Modified's Avatar
Modified
I give you guys credit thinking of the inverter.... The whole reason I was looking was because I kept running out of extension cord!
Old Mar 1, 2006 | 10:17 AM
1975Ford's Avatar
1975Ford
Forget the inverter , stick with the donor truck.. parts. AC compressor with engine bracker and with AC lines , Idler pulley for the AC, Dash with AC vents, AC vents and ducts, The AC assembly (Black AC / Heater assembly), Factory AC switch and heater controls, and condensor unit. My neighbor had mad a template out of some thick construction paper when they had pulled the AC assembly from the firewall, He cut out the paper to match the firewall and then traced out the hole. JMO
________
Buck
