Decoding door tag info
Old Feb 27, 2006 | 07:16 PM
Manwith3fords's Avatar
Manwith3fords
I just bought a 96 F150 4x4, extended cab XLT and got it home today. The door tag says Axle 19, Brakes B, Trans U, can anyone tell me what these are? I haven't gone underneath yet in search of tags for gear ratios and such.
Old Feb 27, 2006 | 07:43 PM
ncranchero's Avatar
ncranchero
19 is a 3.55:1 open rear and the U is a 4R70W. Don't know the brake code right off.
Old Feb 27, 2006 | 07:50 PM
F350JOHN's Avatar
F350JOHN
Axle 19 means: 3800lbs capacity with a 3.55 gear ratio
Brakes ?
Trans U ? I could tell you more based on if its an auto or manual and what engine it has.
So I kinda helped you!
Wish I could help you more!
Old Feb 27, 2006 | 07:58 PM
brosko80's Avatar
brosko80
theres a spot on this site that tells you all that info. not sure exactly where, just do some searching. i would have done the searching and told you where it is but i am to lazy.
Old Feb 27, 2006 | 08:14 PM
ncranchero's Avatar
ncranchero
https://www.ford-trucks.com/article/...de_Chart_.html
Old Feb 28, 2006 | 03:10 AM
Manwith3fords
Thanks guys, I had a 4R70W in my 95 Cougar, it took a dump after 92,000km. This one has 194,000KM on it unless it was rebuilt before I got it. I guess I'm lucky to have a buddy with a transmission business...LOL....It drives great, shifts nice and the fluid is nice and clean. The truck has never been used as a work truck and it's never seen a plow....Cross your fingers...LOL
