Problem...intermittent dying
Old Mar 7, 2006 | 09:41 PM
j11486's Avatar
j11486
intermittent dying
Its pretty easy actually to reach it I used a 10mm socket on a 2 inch extension took me about 8 minutes to change it out. Unfortunately I have a new problem though with steady throttle pressure I get a stutter almost as if the timing is out of whack---any ideas. Oh and by the way the stalling out was my aftermarket chip intermittently coming loose FYI
Old Apr 12, 2006 | 11:02 PM
Bull74's Avatar
Bull74
where is the Cam position sensor located on a 7.3 diesel F-250, mine i think just went out, intermittent stalling. however i cannot find it.?????
Old Apr 13, 2006 | 05:36 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Bull74 to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 13, 2006 | 02:59 PM
ryaneverk2's Avatar
ryaneverk2
Check on the front of the engine, near the main crank pully... passenger side. Lie on your back and look up at it.
Old Apr 13, 2006 | 03:48 PM
hott-rodd's Avatar
hott-rodd
Right beside the pulley, It looks like the reference fin used to set timing.
Look for the bottom on the passanger side.
Old Apr 19, 2006 | 09:33 PM
j11486's Avatar
j11486
int. dying
Hey guys for those that are having stalling and sputtering the first thing i would do is if you have a performance chip in your 7.3 take it out cover the hole where it came from and try that. I have had this problem for too long now truck just dies, sputters, shuts off while driving and then starts back up again on its own, etc etc etc. I replaced the cps, no luck. Replaced the fuel filter and everything else in this thing, no luck. I took out my chip, truck drives like its brand new. Just FYI for those that have a chip and are having this problem and cant get it figured out.
roughridn_sob
Aug 28, 2022 05:51 PM
NC F150
Dec 18, 2016 01:38 PM
SwampFox112
1983 - 2012 Ranger & B-Series
Sep 12, 2016 10:15 PM
Rodney R
Jun 6, 2015 09:02 PM
rlr350z
Jan 13, 2011 06:06 PM
