Injector codes
Old Feb 27, 2006 | 10:12 AM
Kodiak450's Avatar
Kodiak450
Injector codes
My 02 Powerstroke was running very poorly, I shut it off and restarted it and the problem went away. I pulled the diagnostic code with my superchip programer and it was Injector circuit/IDM codes detected, can anyone tell me what this means or what I should do about it, again once I shut the truck off and restarted it the problem went away. I just dont want it to be reoccuring, any help would be great.
Thank You
Old Feb 27, 2006 | 02:31 PM
renchr56's Avatar
renchr56
I think you need to get the actual code number for anyone to help. Maybe not. Possibly someone might be able to help. I just got a code of 0263 finding out the #1 injector is bad.
Old Feb 27, 2006 | 06:42 PM
PSNut's Avatar
PSNut
Yeah...i have a numeric numbered code list from my manual.
Nut
Old Feb 27, 2006 | 06:56 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
one of these?
P0261 Injector Circuit Low - Cylinder 1
P0262 Injector Circuit High - Cylinder 1
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Injector Circuit Low - Cylinder 2
P0265 Injector Circuit High - Cylinder 2
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Injector Circuit Low - Cylinder 3
P0268 Injector Circuit High - Cylinder 3
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Injector Circuit Low - Cylinder 4
P0271 Injector Circuit High - Cylinder 4
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Injector Circuit Low - Cylinder 5
P0274 Injector Circuit High - Cylinder 5
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Injector Circuit Low - Cylinder 6
P0277 Injector Circuit High - Cylinder 6
P0278 Cylinder 6 Contribution/Balance Fault
PO279 Injector Circuit Low - Cylinder 7
P0280 Injector Circuit High - Cylinder 7
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Injector Circuit Low - Cylinder 8
P0283 Injector Circuit High - Cylinder 8
P0284 Cylinder 8 Contribution/Balance Fault
if so, one (or more) of your injectors may be bad, or just not firing.
Old Feb 28, 2006 | 04:48 AM
renchr56's Avatar
renchr56
Yes I know. I have to replace the #1 injector & check for any others not contributing.I don't know why they all can't show up at once. Every time I do Contribution test i always end up replacing 2 or 3 more.
Restlesswildman
Jul 3, 2015 10:06 AM
wfont
1983 - 2012 Ranger & B-Series
Apr 6, 2015 08:39 AM
cmoerg
Jul 26, 2014 12:11 PM
98rangerll
Jan 11, 2014 01:18 AM
Bowtie_Schmowtie
Jul 29, 2013 10:52 AM
