Sponsored by: Auxito
Trailer Tow Package
Old Feb 27, 2006 | 05:14 AM
ALAN_50501's Avatar
ALAN_50501
Trailer Tow Package
I have a 1997 ford f150 larit 5.4was wondering how i can tell that i have the tow package..how can i tell that the radiator has been upgraded and will it have transmission oil cooler?? i think i have the 7 pin harness??what should i look for to see about the radiator??
Old Feb 27, 2006 | 11:49 PM
Racerguy's Avatar
Racerguy
Anyone?
Old Feb 28, 2006 | 07:40 AM
ranger88a's Avatar
ranger88a
If the 7 pin harness is there, and factory it should have trailer tow. You should have a trans cooler in front of the radiator. Follow the trans lines and they should lead you to the cooler.
Old Feb 28, 2006 | 08:57 AM
97F260LD's Avatar
97F260LD
trailer tow package
In 1997, the Trailer Towing Group (option 535) included the following:
3.73 rear axle ratio
7-Wire Trailering Harness
Class III Hitch
Heavy Duty Service Package (option 53C) which includes:
130 Amp Alternator
Heavy Duty 78 Amp Battery
Super Engine Cooling
Auxiliary Transmission Oil Cooling (w Auto Trans)<O</O
I have a ’97 F250 Light Duty with a 5.4L and this equipment, looking inside the bumper opening is two small coolers, the larger water cooled one to the left is a trans cooler, the smaller air cooled one on the right is a power steering cooler. A factory equipped harness will have ford inscription on the plug cover.
Old Feb 28, 2006 | 09:15 AM
KingRanchMan02's Avatar
KingRanchMan02
If your truck was built with the Class III trailer towing package, this includes the 7 pin wiring harness, Class III frame-mounted hitch receiver, heavy duty shock absorbers, 72 amp hour battery, and a transmission auxillary oil cooler.
My 2002 King Ranch Lariat also came with a wiring harness for connecting a brake controller, and a couple of relays. One is titled as the Trailer Tow Battery Charge Relay, and the other as the Trailer Tow Backup Relay. Check your owners manual for the location of these relays in the under hood power distribution box.
Old Feb 28, 2006 | 09:17 AM
ALAN_50501's Avatar
ALAN_50501
i do have a brake controller on mine
Old Feb 28, 2006 | 10:24 AM
MrBSS's Avatar
MrBSS
Well, the brake controller itself would not be factory installed in any case.
Old Feb 28, 2006 | 11:07 AM
97F260LD's Avatar
97F260LD
Mine also came with a brake control harness, also included an adapter for seven to four pin connection. When I bought the truck new it was in a plastic bag with instructions behind the driver's seat. MrBSS is correct, I had to purchase the brake controller, it is not factory supplied.
Old Mar 2, 2006 | 08:50 PM
axman's Avatar
axman
is there anyway to look up what option were installed at the factory? vin#?
Old Mar 3, 2006 | 09:29 AM
Forddieselweasel's Avatar
Forddieselweasel
yea that would enteresting to know
Old Mar 3, 2006 | 11:23 AM
KingRanchMan02
There is a VIN decoder at www.fleet.ford.com/maintenance/
The VIN will tell you,
  • Manufacturer
  • Brake Type and GVWR Class
  • Line,Series Body Type
  • Engine Type
  • Model Year
  • Assembly Plant
The VIN will not tell you what options came on your truck. The door frame tag has more detailed information. For a decoder, go to
https://www.ford-trucks.com/article/...r_Decoder.html
Old Mar 3, 2006 | 01:19 PM
KingRanchMan02
VIN decoder link is www.fleet.ford.com/maintenance/maintenance.asp
mike91911
All Things Towing
Feb 27, 2009 04:22 PM
SG1NUT
Mar 20, 2008 08:50 PM
bentonsexpy
Sep 20, 2007 01:52 PM
grantorino
Jul 11, 2006 02:47 AM
