cooling system
Old Feb 26, 2006 | 12:47 PM
white 94's Avatar
white 94
cooling system
i have a problem withhe cooling system. i put in a bottle of sealer into the radiator to stop a leak. it stopped the leak, but now the temp gauge goes up and down from cool to hot all the time. i put a new thermastat in and it still does it. any help on what might be causing this would be great!
Old Apr 26, 2006 | 04:40 AM
krankshaft's Avatar
krankshaft
Thats the reason why you don't use stop leak as I say it doesn't target anything so it plugs everything. Your coolant passages have probably been constricted by the stop leak and the cooling system is operating inefficiently.
The only way to remedy this is to either backflush the system with a kit to get this junk out or have it flushed professionally. After the flush get a new radiaitor or you could possibly get the old one repaired at a radiator shop.
Old Apr 26, 2006 | 04:46 AM
krankshaft's Avatar
krankshaft
Please delete this message.
Old Apr 27, 2006 | 12:53 AM
Jharger's Avatar
Jharger
No - do not delete this message. You are right. Stop leak is the worst thing you can ever add to your cooling system...unless you are in some kind of a pit race situation.
Reason why the temp gage goes up and down is the thermostat is now compromised.
