Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
vacum pump brake bleeder ?
Old Oct 18, 2002 | 09:12 AM
Avanti's Avatar
Avanti
Just checking to see if anyone has used the vacum pump brake bleeders you can buy at the auto parts stores for about $30.00. Do they work better than the old foot pump method? Do they work better with the antilock systems? I have used the foot pump method for years on my 89 & 92 Ford trucks but heard it works better on the brake systems like in the 93 Aerostar.
Old Oct 18, 2002 | 01:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
I finally broke down and bought one.
They work great until you get enough vacuum that they pull air past the master cylinder seals. I ran into that little problem while trying to bleed a clutch cylinder on an Isuzu Trooper. On that job I ended up shortening the line and re routing it so that it did not have three high points in the line, -stupid system.
Otherwise they do work well. They work real well when you don't have a "pumper" for your brakes. They are also great for fluid changes, nice and neat.
They also have uses for vacuum testing components etc.
Very handy!
Old Oct 19, 2002 | 02:57 AM
groundrat's Avatar
groundrat
