Sponsored by: Real Truck
Tire Help
Old Feb 26, 2006 | 08:23 AM
DUB85's Avatar
DUB85
Tire Help
I Have A 2003 F-350 X-cab. Im Looking To Put New Tires On, Will 315/75/16 Tires On 16x10 Rims Fit On The Truck W/o A Lift Or Can I Get By With Just Doing A Front Leveling Kit? No Rubbing Issues With A Leveling Kit Right? Let Me Know, Thanks.
Old Feb 26, 2006 | 10:19 AM
BobbyDiesel71's Avatar
BobbyDiesel71
I bought 305/70R16 Nitto Terra grapplers to replace the stock 265's and ahve had no rubbing issues at all, I have a 2002 F-350 4x4 stock height.
I intend to install a leveling kit in the near future and I think there is enough room to run 315's for sure if not 325's!!!!!
good luck!!!
Old Feb 27, 2006 | 07:55 PM
Ronin007's Avatar
Ronin007
It depends. What springs are on your truck? What offset are your wheels? What size leveling kit are you looking at? Generally speaking 285/75 or 295/75 tires on the stock 16x7 rims will fit on our trucks without any modifications. 305/70's will fit on stock trucks with x-springs and proper offset wheels most of the time. Last summer I installed a 3.5 Fabtech hanger kit for plowing purposes and I could probably easily fit 315/75's on it. Check out my gallery.
BTW where in NY are you located? The NY Chapter is starting to plan some G2G's (Get 2 Gethers). Check out the thread in the NY Chapter forum.
