kickdown linkage
Old Mar 25, 2001 | 06:29 PM
nitrous125's Avatar
nitrous125
kickdown linkage
howdy everyone i posted this messege in another bord but not to many people answered. the question is. i put a 2 in spacer on my 390 so my carb would clear some lines that were infering with it. when i did this my kickdown is way off and need help bad because i like my kickdown. it is hooked to a c6 tranny. please help me
Old Mar 25, 2001 | 09:38 PM
jowilker's Avatar
jowilker
kickdown linkage
Bend it to fit.:-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Mar 25, 2001 | 09:54 PM
nitrous125's Avatar
nitrous125
kickdown linkage
i have tried to bend one and it never worked after i bent it. so i need some other advise thanks
Old Mar 25, 2001 | 11:57 PM
oz9609's Avatar
oz9609
kickdown linkage
Cut 2 inches from an old one and section it into the one you will be using. I'd suggest you put the section on the most vertical place right behind the bellhousing since you need to go up instead of forward. Be sure it will clear the cab.
Old Mar 26, 2001 | 06:50 AM
jowilker's Avatar
jowilker
kickdown linkage
Then get someone else to help you bend it. You are asking like you think, that because you have added a custom part under your carb, that Ford just made a kickdown for you. HELLO
John
jowilker
66F100s Rule
Old Mar 26, 2001 | 07:42 PM
nitrous125's Avatar
nitrous125
kickdown linkage
i found these kickdown cables in summit they cost $51. would these cables work? and if so how could they because ford kicks down not pulls up. thanks
Old Mar 28, 2001 | 07:50 PM
impact's Avatar
impact
kickdown linkage
Old Apr 1, 2001 | 11:55 PM
Radar's Avatar
Radar
kickdown linkage
I put a 1" 4-hole spacer under mine and had to make mine longer, I cut the tube just above the bellhousing and added a 3" piece of tubing and drilled the ends and screwed it together. If you bend the tube, remove the tube first, I didn't and it bent the kickdown lever in the trans. Its fixed now :-)
http://www.radarscastle.com/images/ford-tough.gif
Find out what CFM carburetor you need use this program.
http://www.radarscastle.com/cid2cfm.zip
My Truck
http://www.radarscastle.com/MyTruck/index.htm
