Question for the pros...
Old Feb 25, 2006 | 08:20 PM
transporter's Avatar
transporter
Exclamation Question for the pros...
1999 7.3l diesel dually used for car hauling...Had it since new - now it stands at 82000 miles with no major problems. Here is the strange occurence. My driver called in saying that the tranny wont shift from 2nd up - only 1st to 2nd and reverse. Truck acted up first on the California GrapeVine at high elevation it seemed to slip up into a high rev, taking the foot off the acceleration fixed the problem. The truck made it close to home when the problem came back - driver went over a bump, high rev and then just 1st and 2nd gear with the OD light blinking but this time the problem stayed. I cleaned the VSS, checked fluids, reset battery in hope of a computer malfunction - Nothing, only 1st and second gear! Towed the truck in to the Tranny shop and left it overnight. In the morning, truck shifts great - it shows no codes. I had the shop take the pan down - no shavings, tested the solenoid -OK, tested the VSS - oK, the fluid is in perfect shape! So what gives???? The ABS light came on but I think that's just a coincidence - it's time for front rotor and pads change...Please someone help me - I'm afraid to send the truck out to the east coast!
Old Feb 25, 2006 | 09:17 PM
jtharvey's Avatar
jtharvey
Your OD light flashing indicates a code in the computer. It would be good to know what those codes are. But, I'm afraid you reset them by unhooking the batteries. You may have to wait for the OD light to blink again to see what the codes are.
Old Feb 25, 2006 | 10:43 PM
Kwikkordead's Avatar
Kwikkordead
Welcome to FTE transporter.
I remember reading a few posts about frayed wiring harness's across the top of the transmission. The bump in the road gave me that thought.
Old Feb 26, 2006 | 01:17 AM
transporter
Not one frayed wire...Everything is like new...
Old Feb 26, 2006 | 09:56 AM
Casey's Avatar
Casey
You could have had a stuck shift solenoid or a stuck shift valve. Without the code that was erased from the computer there is no way to tell.
There's no way the VSS had anything to do with it.
If it happens again read the code that is stored in the computer. You'll need a Ford specific scan tool to read the code.
