351m-351w engine swap
Old Mar 30, 2001 | 07:54 PM
trukster59's Avatar
trukster59
I would like to put the 351w engine from my 85 ford van into my 78 ford f150 (which currently has a 351m engine). Do I need special engine mounts? Where do I find them?
Thanks
Old Mar 30, 2001 | 09:00 PM
Nathan's Avatar
Nathan
I think your engine perches will work with W mounts. You do know the tranny bolt patterns are different, right? Thats probably the biggest problem with your swap.
Nathan
Old Apr 1, 2001 | 07:07 PM
Nathan's Avatar
Nathan
Old Apr 2, 2001 | 05:45 PM
loudfords's Avatar
loudfords
You need to get engine mounts from a 302 or 351W truck motor. The van engine mounts are quite different. Both my 351W's came from vans. Get a tranny from a 302 or 351W van or truck (should be plenty around) and get ready to have fun. The 351W is much more fun than the 351M (and I speak from experience)
Any other questions about the swap just feel free to ask.
1979 F150 Custom: 75 351W, Edelbrock & Holley
1987 F150 XLT Lariat: 88 351W EFI
Chevy 454: waiting for a truck (Mazda?Nissan?)
Old Apr 2, 2001 | 08:26 PM
BigBrownTruck's Avatar
BigBrownTruck
You are going to have to be creative about exhaust. Maybe the Y pipe from the van will work? Or have Duals fabbed at exhaust shop if legal. I'm under the understanding that the angle off the heads of the M's cleveland style heads, would mean that the exhaust locates differently between the two engines. I have yet to find a listed application for 351w headers in 70's era trucks. Your Windsor should sit fine on the M's engine perches, you might need pickup motor mounts though, from a 302. When I bought engine perches for the 302 in my 76, the truck specialty yard I got them at had them labeled for 302,351,400. I almost replaced the bad 302 I had w/ a 351w but got gunshy about exhaust since it wasn't going to be technically legal for me to have duals fabbed and just the expense of having an exhaust shop make special pipes discouraged me from low dollar solution.
BBT
Old Apr 3, 2001 | 04:47 PM
loudfords's Avatar
loudfords
If your truck is 2wd you definitely need custom exhaust, the van pipe won't clear the crossmember between the cab mounts. For wiring, just use the harness off of the M or get one from a 302 truck of the same year.
Old Apr 3, 2001 | 04:48 PM
loudfords's Avatar
loudfords
Oh, and also if your truck is 2wd you need to find a front sump oil pan and pickup tube to make the engine fit.
alex.g
Oct 5, 2013 10:04 PM
heybrent
1978 - 1996 Big Bronco
17
Oct 6, 2009 06:01 PM
JCastellaw
1966 - 1977 Early Broncos
Oct 19, 2006 02:34 PM
FordRacing2
15
Aug 12, 2003 09:39 PM
DogFuzz
Aug 3, 2003 10:07 PM
